    EXT4 instead of EXFAT
    Emulator Arcade/PC/Console
    ext4 instead exfat
    • Pepins
      Pepins last edited by
      Hi everybody!
      There is a way that I can use EXT4 instead of EXFAT in the SHARE partition?
      I want to use linked files and folders.
      Thanks!
      Alvin davidb2111 2 Replies Last reply Reply Quote 1
      • Alvin
        Alvin Banned @Pepins last edited by Alvin
        @Pepins
        Where ?
        On the SD-Card Recalbox is instsalled on or an external Storage like an USB-Sick a HDD ?
        For an external Storage here
        https://wiki.recalbox.com/en/tutorials/system/installation/usb-device-as-storage
        it says you had to use the exFat Filesytem.
        But it also says that Recalbox doesn't format the external Storage.
        So why don't you give it a try ?
        Format the external Storage with EXT4 and see if this will work.
        For the internal SD-Card I didn't think it will work, because when Recalbox is installed it formatted the Card and build all the nessesary Partitons.
        If you afterwords format the Partion in another way (I don't know if this is even possible - maybe with GParted) Recalbox would'nt find this Partiton anymore.
        I'm using Recalbox 6 on a Raspberry Pi 3B+ and a NTFS-formatted external HDD works fine as Datastorage.
        • davidb2111
          davidb2111 Staff @Pepins last edited by
          Hi @Pepins
          First make a backup of all files under SHARE partitions.
          Then, you can format SHARE partition manually in EXT4 format:
          Extract SD card and format the second partition (/dev/sdX2, change X accordingly) from a regular linux system.
          Finally, restore backup on the new SHARE partition.
          ssj17vegeta 1 Reply Last reply Reply Quote 0
          • ssj17vegeta
            ssj17vegeta @davidb2111 last edited by
            @davidb2111
            That's really interesting.
            Are you sure it plays well with the update process ? Just in case there are updates, I wouldn't want them to mess this up.
