    Menu sound volume
    sound volume
    • ferminote
      ferminote last edited by
      as I can lower the volume menu ( not silence ) and the volume of games is higher ? the problem is that the menu is listening volume higher than the games and I would like it to be the other way around . thanks!
      • mostlydave
        mostlydave last edited by
        I was also unable to find a way to lower the menu music volume so I just disabled it. It's a shame because I really liked the menu music but it was way to loud every time you exit a game. Is there any plans to make it adjustable independent of game volume?
        • scal21
          scal21 last edited by
          @mostlydave said in Menu sound volume:
          Hey guys,
          i had the same issue. This worked out for me:
          I just lowered (normalized ca. -10dB) the volume of the background music-files.
          The ".ogg"-Files are located in the theme Folder. Path of the Default theme:
          /recalbox/share/system/.emulationstation/themes/recalbox/music
