    Composite not possible?
    composite
    • thehassle
      thehassle last edited by
      Hi folks i tried to run RecalBoxOS on a small LCD with composite IN. So i edited the PI config.TXT to Composite mode and it works fine with noobs and RaspiOS. The i edited the recalbox conf and set <span style="font-family: Consolas, 'Liberation Mono', Menlo, Courier, monospace; background-color: transparent; font-size: 14px;">global.videomode=CEA 4 HDMI to </span><span style="font-family: Consolas, 'Liberation Mono', Menlo, Courier, monospace; background-color: transparent; font-size: 14px;">global.videomode=default.</span> But... theres no Composite Output at all. Wheres my fault?!
        did you follow this wiki ? https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN)
        • nosfay
          nosfay last edited by
          On my rpi0 , I had to clean my config.txt because some weird characters appeared at the end (like "^M"), composite worked fine after.
            some weird characters appeared at the end (like “^M”)
            you need use notepad++ via winscp or nano in ssh for exemple, not use notepad of windows : https://github.com/recalbox/recalbox-os/wiki/acces-via-WinSCP-(FR)
            • nosfay
              I always use nano.
              101.4k
