    Theres some way to turn on FM sound on Master system emulator on recallbox
    Emulator Arcade/PC/Console
    theres turn sound master recallbox
    • fabiobr
      fabiobr last edited by
      Hi
      Theres some way to turn on FM sound on Master system emulator on recallbox ?/   Thx a lot
      • esmith13
        esmith13 last edited by
        if it's possible on recalbox at all you have to be using the GenesisPlusGX core and open up retroarch's quick menu and disable FM sound under options. PicoDrive does not have that feature and it is the default emulator for sega consoles. To change the default emulator for a specific rom (I recommend this way since GenesisPlusGX is not as smooth on the Pi as PicoDrive) you go to the rom in emulation station and press select to edit the rom metadata. First two options should be set to libretro and GenesisPlusGX. This will force that emulator to be used always for that one rom. Alternatively (and not recommended) you can change ALL master system games to use GenesisPlusGX by pressing start in ES and going to the GAMES menu, ADVANCED, Master System and change emulator to libretro and core to GensisPlusGX. Here's a list of roms that support FM sound if you use the preferred method and want to edit the metadata just for that handful of roms: http://segaretro.org/FM_Sound_Unit Hope this helps Eric
        My Raspberry Pi's:
        Pi A, Pi B, (2) Pi B+, (2) Pi 3
        Currently looking for a reason to buy a Pi Zero or two ;-)
