    Retroarch not saving hotkey option...
    retroarch saving hotkey option
    • Echdaron
      Echdaron last edited by Echdaron
      Hi there,
      I had some issues with my controller (NES30 Pro) but discovered it has something to do with the option to configure the settings from within Recalbox.
      So, as I wanted to change the default hotkey button (set at '13' - which is the press on the left joystick) and change it to '10' (the SELECT button), I went into the CLI :
      1. found the .cfg under /recalbox/share/system/configs/retroarch (retroarchcustom.cfg)
      2. vi'd the setting (changed it to '10'), saved it, rebooted the Pi and noticed that it was back at '13' (input_enable_hotkey_btn)
      3. tried to change it via the Retroarch menu (press '13' and the B button), entered '10' as the hotkey, saved it as the main config, rebooted and it stayed at '13'.
      Anyone having any ideas please?
      thanks!
      /d
      Small update : saw this posting : https://forum.recalbox.com/topic/27603/8-1-issues-on-my-pi-4/8 - mod was suggesting an option override... Will try it later but it's still strange that the changes are not being saved/kept. Even in CLI...
      Echdaron 1 Reply Last reply Reply Quote 0
      • Echdaron
        Echdaron @Echdaron last edited by
        @echdaron This is solved by the override .cfg - created one with a single value (under /recalbox/share) and called it .retroarch.cfg...
