    Xbox 360 wired pad rumble doesn't work
    Your discoveries
    xbox 360 wired pad rumble doesnt
    • emuemu
      emuemu last edited by
      Hi! Hi have a problem on My py3 b+ (recalbox last version). My Xbox 360 wired version pad does not vibrate.
      In the retroarch menu the rumble is active and at maximum power, the pad is placed in the "generic" category but I also tried to change to "DualShock" without results...are there any solutions?
      mathygreen 1 Reply Last reply Reply Quote 0
      • mathygreen
        mathygreen @emuemu last edited by
        The Wired controller for X-box 360 and PC Windows 10 / 8.1 / 8/7 game system. The ergonomic design, double vibration and an amazing set you in endless gaming experience.
        If your Xbox One Wireless Controller is not vibrating even with the vibration setting turned on, the controller might need to be charged.
        The Xbox One Wireless Controller may not vibrate when it has low battery power in an effort to save battery life.Plug the controller into the Xbox console using a USB cord.
        Reliable Permit Solutions, LLC
        Alvin 1 Reply Last reply Reply Quote -1
        • Alvin
          Alvin Banned @mathygreen last edited by Alvin
          @emuemu said in Xbox 360 wired pad rumble doesn't work:
          @mathygreen said in Xbox 360 wired pad rumble doesn't work:
          So did you notice what's wrong here ?
          And what's with the Reliable Permit Solutions, LLC you linked ?
          We don't need any trucking Permits here !
          @emuemu
          Maybe there is a Problem with the latest Version (8.1.1) of Recalbox
          Look here
          https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/controllers
          It says that the last Version of Recalbox the Xbox 360 Controller was tested with is 8.0.0
          Maybe you should try to rest your RecalBox to Factory Settings and see if the Controller works than.
