    GPi Case 2 + SN30 Pro (Wireless) No Ingame Controls
    GamePad/GPIO/USB encoder
    gpi case sn30 wireless ingame controls
    • tobiwan_1984
      tobiwan_1984 last edited by
      Hello everybody,
      experiecened some odd behavior with a GPI Case 2 and a 8bitdo SN30 Pro on Recalbox 8.1.1.
      While the Controller is connected wired, everything works. I can use it within ES and in games.
      As soon as I connect it via bluetooth, tough it is still working within ES, in-game it stops working.
      Changing order (P1 - P2) in Controller Menu (the GPI Case built in Buttons shown as a XBOX360 Wireless Controller) does not help.
      Anybody has an idea? It seems the built-in controls are blocking other bluetooth controls. Even tried a XBOX One Wireless I had lying around with same results.
      lhari84 2 Replies Last reply Reply Quote 0
      • lhari84
        lhari84 @tobiwan_1984 last edited by lhari84
        @tobiwan_1984
        Hi, I got same issue. In my case I recognized that when I configure the controller, Buttons R2 and L2 are recognized as "Axis" and not "Buttons". So I exluded them for testing and afterwards it worked.
        Anyway, I would like to use these controllers including L2+R2 buttons. In the past they worked, but I can't remember if recognized as "Axis" or "Buttons". Hope the Recalbox Team has a solution for it.
        Pi 4:
        Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
        Pi Zero 2W:
        GPi Case 2W, Recalbox 9.0
        lhari84 1 Reply Last reply Reply Quote 0
        • lhari84
          lhari84 @lhari84 last edited by
          @lhari84
          Some more details, in my case it's a SF30 Pro, with latest firmware released for it, 1.34.
          Futher, it's set to Android mode (like recommended?)
          Pi 4:
          Pi Zero 2W:
          • lhari84
            @tobiwan_1984
            I've found a workaround, at least partially... If you press both L2 and R2 button, after loading the game, it will work. But sometimes there occurs a malfunction that enables a shader.
            Pi 4:
            Pi Zero 2W:
