    [4.0.0] N64 USB Controller Mapping
    GamePad/GPIO/USB encoder
    [4.0.0] n64 usb mapping
    • avi7x
      avi7x last edited by
      Hey Guys, the DragonRise Inc. Generic USB Joystick doesn't work on 4.0.0. I have tried many configurations for this controller in the es-menu, but nothing is working. The mapping should be:   DPad R = "axis(0+)" DPad L = "axis(0-)" DPad D = "axis(1+)" DPad U = "axis(1-)" Start = "button(9)" Z Trig = "button(8)" B Button = "button(4)" A Button = "button(5)" C Button R = "button(1)" C Button L = "button(3)" C Button D = "button(2)" C Button U = "button(0)" R Trig = "button(7)" L Trig = "button(6)" Mempak switch = "" Rumblepak switch = "" # Analog axis configuration mappings X Axis = "axis(0-,0+)" Y Axis = "axis(1-,1+)"   Editing the mupen64plus.cfg and AutoInputCfg.ini doesn't work because recalbox overrides everything with the es-mapping. Is there any solution to get this controller working on mupen64plus ? Thanks
        Hello can you start this script /recalbox/scripts/recalbox-support.sh and give us the generated file.
          Same bug here : http://blog.recalbox.com/forums/topic/n64-usb-controller-mapping/
          • avi7x
            Sure: http://www23.zippyshare.com/v/GgmE6anR/file.html
            101.4k
