    No sound via hdmi
    sound hdmi
    • mudlee
      mudlee last edited by
      Hi Guys!
      I've recently bought a raspberry zero 2 starter kit. I installed recalbox with Pi Imager. The version is 8.1.1-ELECTRON.
      My problem is that I connected the pi to my monitor via hdmi and I have no sound. I tried lots of things I found over the forums, but still I can only see at settings/sound settings/output device: DUMMY OUTPUT.
      I tried to edit the config and force hdmi instead of auto via ssh, I tried to run alsamixer and set it there, but nothing.
      The hdmi cabel must work, I installed retropie and I had sound there, but I'd like to use recalbox.
      Any idea what to do?
      • rachelgomez123
        rachelgomez123 last edited by
        No sound or audio from the source device when connected to the TV with an HDMI cable
        To perform a power reset. Turn off the TV, unplug the power cord for two minutes, then turn on the TV.
        Restart the TV by selecting the option depending on your TV.
        This may help you,
        Rachel Gomez
