    My lightgun project, I need help to finish.
    Emulator Arcade/PC/Console
    lightgun project need help finish
    • Gogoye2
      Gogoye2 last edited by
      Hello to all
      I finally took the time to work on my lightgun project on bootable USB key.
      I have Wiimote + DolphinBar, all is fine but there are some games I can't play.
      The List :
      Super nintendo
      • Terminator 2 -> the light gun is uncontrollable and unplayable.
      Megadrive
      • Terminator 2 -> unable to select the gun mode, controller only
      Master System
      • Space Gun -> unable to press "Pull the trigger"
      • Wanted -> unable to press "Pull the trigger"
      Dreamcast
      • Confidential Mission -> I get stuck at the beginning, I can't choose a save game
      PSX
      • Elemantal GearBolt -> I have no menu
      • Project-Horned Owl -> Wiimote not detected and impossible to calibrate
      Can someone help me to play with my lightgun on this games ?
      Best Regards
      • recalboxfan1
        recalboxfan1 last edited by recalboxfan1
        Have you checked the file “lightgun.cfg” on the system? It governs the controller presets for the automatic lightgun configuration and has quite a lot of notes and commentary which may help you here.
        EDIT: the aforementioned file is actually on the Recalbox itself (forgot what folder) but here’s what I think is the latest version of the file viewable online: https://gitlab.com/recalbox/recalbox/-/blob/master/board/recalbox/fsoverlay/recalbox/share_init/system/.emulationstation/lightgun.cfg. You can search for the game name/platform and see what comes up.
