    Accidentally loaded state: why not add a confirmation pop-up?
    accidentally loaded state confirmation pop-up
    2289
    • Neckara
      Neckara last edited by
      Hi,
      I accidentally loaded a save state instead of saving one (depending on the console/joystick Y is for saving or loading save state which is quite confusing).
      This is quite troublesome as I lost all progress that I made.
      Couldn't it be possible to add a confirmation pop-up to prevent such mistakes ? Or to save the current state in a dedicated slot before loading in order to be able to cancel a load state ?
      Thanks in advance,
      Cordially,
      Scavy Zing 2 Replies Last reply Reply Quote 0
        Scavy Global moderator @Neckara last edited by
        @neckara hello
        your request has been pushed to the dev team. ^^
        • cdtpepette
          cdtpepette last edited by
          Hello,
          There is an option in retroarch to cancel a savestate load. It helped me twice.
          Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
          Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
            Zing Global moderator Translator @Neckara last edited by
            @neckara There are options to Undo Save State and Undo Load State, as cdtpepette commented, see this video:
            https://youtu.be/cNPtAOjaDJE?t=317
            Neckara 1 Reply Last reply Reply Quote 1
            • Neckara
              Neckara @Zing last edited by
              @zing Thanks for your answer.
              When I was searching for a way to undo load state, I didn't looked at videos. I only found the wiki page about the shortcuts ( https://wiki.recalbox.com/en/basic-usage/getting-started/special-commands/in-game ), and some forum threads like in reddit with no solutions.
              (and now this thread is top result in Google for this search xD).
              I tried to search a little in the Wiki, is this information in the wiki ?
                @neckara
                I don't think so, honestly I've never used this function and I don't remember seeing anything about it on the wiki. But, that's why I like the forum, now it's registered here, if in the future someone needs this function, a simple forum search will solve it.
