    FB Neo slow in some games
    Emulator Arcade/PC/Console
    neo slow
    2373
    • Asirome
      Asirome last edited by
      Hi,
      I have installed Recalbox 8.1 on a Rasberry 3B+ and I have detected that some games like Golden Axe 1 and 2 doesn't run at full speed with the default settings for FB Neo.
      The same games works fine with the same hardware with Batocera v34. 🤷
        Zing Global moderator Translator @Asirome last edited by
        @asirome
        • https://wiki.recalbox.com/en/advanced-usage/arcade-in-recalbox#iii-romsets
        • https://wiki.recalbox.com/en/tutorials/games/generalities/isos-and-roms/romsets-for-recalbox
        Asirome 1 Reply Last reply Reply Quote 0
        • Asirome
          Asirome @Zing last edited by
          @zing ??
            Scavy Global moderator @Asirome last edited by Scavy
            @asirome hello
            @zing means you may need to check your fbneo roms with clearmamepro using the dat file. You can find it in the bios folder, fbneo folder.
            I don't know if bato v34 uses the same fbneo version as recalbox v8.1.
            • Asirome
              Asirome @Scavy last edited by
              Hello @scavy,
              FB Neo runs slow if the ROM set is incorrect?
                @asirome when FBNeo is b*mped, some roms maybe modified and the emulator itself runs differently. It may be possible that some games run slowly. Just check ur roms.
                You're using a Pi3b, some games will run faster than others (for ex, CPS3 roms shall run slowly).
