    Shader change shortcut not working on 8.1?
    shader shortcut 8.1
    2016
    • tekkenism
      tekkenism last edited by tekkenism
      Hi there.
      I used to replace shaders on-the-fly during a game by Hotkey+R/L buttons.
      However after updating to 8.1, it seems this is gone now. When I try the same key combo, it doesn't change at all.
      Is this a bug, or were the shortcut keys changed in 8.1?
      Any by the way, Screenshot doesn't appear in main menu as a "System" anymore. When I take screenshots, they don't appear nowhere within any menu.
        Zing Global moderator Translator @tekkenism last edited by Zing
        @tekkenism
        • Have you tried remapping your controller in the Recalbox controller settings menu?
        • Are R/L working in games?
        • Have you tried changing the shortcuts in the Retroarch menu (accessible with Hotkey+B)?
        Maybe this topic interests you:
        https://forum.recalbox.com/topic/27216/conseils-tests-et-feedback-shaders-v8-0-2-ou-supérieure
        tekkenism 1 Reply Last reply Reply Quote 0
        • tekkenism
          tekkenism @Zing last edited by
          @zing
          Have you tried remapping your controller in the Recalbox controller settings menu? : Yes.
          Are R/L working in games? : Yes.
          Have you tried changing the shortcuts in the Retroarch menu (accessible with Hotkey+B)? : No. They are default keys.
          Any idea?
            @tekkenism
            Any idea?
            Try changing the hotkeys in the Retroarch menu and test, if I'm not mistaken, after pressing Hotkey+B during a game, the path is:
            Settings > Input > Input Hotkey Binds
            • tekkenism
              @zing I changed (actually not changed but I set the same buttons), now they work. But it obviously seems these settings are corrupted. Just a note for you guys here.
              The main problem is, why it stopped working after 8.1 update.
                @tekkenism Maybe it's just a punctual problem with your joystick, I haven't seen other reports from users yet to prove that it's a bug.
                Sometimes some problems of this type are solved by doing a factory reset, option available through the advanced settings menu (You do not lose any personal files, but you lose all custom settings).
                101.4k
