    Compilation issue for rpi4
    dev developers compilation
    • Aliliche
      Aliliche last edited by
      Good morning all ,
      I am new to recalbox.
      I tried to compile it for rpi4 but it stops on that.compilation_log.txt
      The build repo is empty.
      What is the problem ?
      Thank you all.
      Step 7/13 : ENV PACKAGE ''
       ---> Using cache
       ---> f60e49905a3b
      Step 8/13 : RUN apt-get update -y && apt-get install -y tzdata && ln -fs /usr/share/zoneinfo/Europe/Paris /etc/localtime && dpkg-reconfigure --frontend noninteractive tzdata && apt-get -y install build-essential git libncurses5-dev qt5-default qttools5-dev-tools mercurial libdbus-glib-1-dev texinfo zip openssh-client libxml2-utils libpng-dev software-properties-common wget cpio bc locales rsync imagemagick bison flex bsdmainutils nano vim automake autopoint mtools dosfstools subversion openjdk-8-jdk libssl-dev libelf-dev graphviz python-matplotlib python-numpy python-six re2c libc6-dev-i386 libtool cabextract && rm -rf /var/lib/apt/lists/*
       ---> Using cache
       ---> 940a937b344d
      Step 9/13 : RUN echo "en_US.UTF-8 UTF-8" > /etc/locale.gen
       ---> Using cache
       ---> 5af4a1cf05c1
      Step 10/13 : RUN locale-gen
       ---> Using cache
       ---> 3fccacff746d
      Step 11/13 : RUN mkdir -p /work
       ---> Using cache
       ---> 8cb487cea9f4
      Step 12/13 : WORKDIR /work
       ---> Using cache
       ---> 5868bdd9e303
      Step 13/13 : CMD echo ">>> Setting recalbox version to ${RECALBOX_VERSION}" && echo "${RECALBOX_VERSION}" > board/recalbox/fsoverlay/recalbox/recalbox.version &&     echo ">>> Fetching and reseting buildroot submodule" && ( git submodule update --init ; cd buildroot && git reset HEAD --hard && git clean -dfx ) &&     echo ">>> Making recalbox-${ARCH}_defconfig" && make recalbox-${ARCH}_defconfig &&     export RECALBOX_CCACHE=${RECALBOX_CCACHE_ENABLED:+"BR2_CCACHE=y BR2_CCACHE_DIR=/share/ccache BR2_CCACHE_INITIAL_SETUP=--max-size=500G BR2_CCACHE_USE_BASEDIR=y"} &&     echo ">>> Make with command : BR2_DL_DIR="/share/dl" $RECALBOX_CCACHE $PACKAGE" &&     make BR2_DL_DIR="/share/dl" $RECALBOX_CCACHE $PACKAGE
       ---> Using cache
       ---> 124053b265bb
      Successfully built 124053b265bb
      Successfully tagged recalbox-dev:latest
      Use 'docker scan' to run Snyk tests against images to find vulnerabilities and learn how to fix them
      >>> Setting recalbox version to development
      fatal: detected dubious ownership in repository at '/home/vicious/recalbox-rpi4'
      To add an exception for this directory, call:
      	git config --global --add safe.directory /home/vicious/recalbox-rpi4
      • RustyMG
        RustyMG last edited by RustyMG
        @Aliliche I may not be quite understanding your query, but, why are you compiling it ?
        You go to the download page, pick the image for the Pi4, install it, and thats you ready to go.
        Its nothing like Retropie where you can install other emus etc or compile source code on an install.
        https://www.recalbox.com/download/stable/
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        100.9k
