    SOLVED!! - No Controllers Found on Recalbox 8.0.2 on Raspberry Pi 4b (8GB) using 8Bitdo SN30 Pro controllers
    GamePad/GPIO/USB encoder
    solved recalbox 8.0.2 8gb 8bitdo
    • PotatoNinja
      PotatoNinja last edited by PotatoNinja
      PROBLEM
      I turned on my controllers with Start + B as always.
      I installed a fresh copy of Recalbox 8.0.2.
      I go to Pair a Bluetooth controller, and set the controller to bluetooth pairing mode.
      After a few seconds, Recalbox says "No controllers found".
      I updated my SN30 Pros to the latest firmware.
      I tried setting controllers.bluetooth.ertm=0 as another post said to try. No change.
      SOLUTION:
      I set controllers.ps3.enabled=0 and it FINALLY WORKED!!
      I hope this helps someone else, because I couldn't find how to do this and tried for hours.
        Scavy Global moderator @PotatoNinja last edited by
        @potatoninja hello
        Did you set this settings in the recalbox.conf file ?
