    Unsolved Joysticks keep saying disconnected/reconnected
    GamePad/GPIO/USB encoder
    joysticks keep saying
    • TheDude 0
      TheDude 0 last edited by
      DragonRise Inc. Generic USB Joystick keeps disconnecting/reconnecting every time I go into Recalbox.
      Using a Raspberry Pi 4
      PS: official PS that came with Pi
      Just switched from one set (2 players) to another set of DragonRise joysticks, no issues on the previous set. No other changes.
      Now, every time I start Recalbox, it basically locks up for about 30 seconds and says the DragonRise Inc. Generic USB Joystick has been unplugged, and then another popup that says its been connected. The same thing happens every time I close a game and go back to Recalbox. Happens for both joysticks.
      After the 30-ish seconds, everything works great, can play games with no issues. Until I go back into Recalbox and then it has to find the joysticks again.
      I've tried doing a factory reset, as well as just connecting 1 joystick at a time, doesn't matter, still happens.
      Also noticed that if I connect just an Xbox 360 controller, no issues. But if I have the 360 controller and the joysticks connected, it also says the 360 controller was disconnected/reconnected when the joystick messages come up too.
      Any ideas?
      • TheDude 0
        @thedude-0
        Update: I ended up swapping the encoder boards from the working set to the non-working set, kept everything else the same (buttons, joystick, ect). Issue has gone away, so it was the encoder boards.
        I now have the working set on the Raspberry Pi 4, and the non-working set on another control board that's connected to a PC running Recalbox. It doesn't have any issues on the PC, so its something with those particular boards and the Pi.
        I'd still like to know what the issue could be. Here's the joysticks I use:
        Non-working set: https://www.amazon.com/dp/B07QRRLCKD?psc=1&ref=ppx_yo2ov_dt_b_product_details
        Working set: https://www.amazon.com/dp/B07JFXQSM5?psc=1&ref=ppx_yo2ov_dt_b_product_details
        Lukete 1 Reply Last reply Reply Quote 0
        • Lukete
          Lukete @TheDude 0 last edited by
          @TheDude-0 Hi The Dude. I have the same problem, exactly like you. Do you know how to resolve? When I connect only one DragonRise I have no problem, but when I conect the second player (two players at the same time), it spend 30 seconds to star working, and if I connect another gamepad , it never works.
          I hope you can help me.
          Bye
