    Shader Lag
    shader lag
    1949
    • roman126
      roman126 last edited by roman126
      Is it normal to have shader lag on Pi 400 with the latest version of Recalbox? Mame, Megadrive, etc are laggy with shaders applied?
      Ideally I’d use the Retro shader setting which applies the community selected shaders per system. First game I tried on Megadrive was laggy.
      I read somewhere to make sure Rewind was unchecked, but this made no difference.
      • airdream
        airdream Theme moderator @roman126 last edited by airdream
        @roman126
        it seem it's an issue with the new RPI driver
        until it will be fixed, you should use another shader than "retro"
        You can try CRT Caligari (very close to retro effect)
        I have edited some CRT shaders here, have a look !
        https://forum.recalbox.com/topic/26968/shader-crt-dithering-réglages-perso
        roman126 2 Replies Last reply Reply Quote 0
        • roman126
          roman126 @airdream last edited by
          @airdream Thanks I thought there was an issue somewhere. I had no issues years ago with older Pi”s and older versions of Recalbox.
          I will try your suggestions.
          Again I appreciate the reply. Thanks
          • roman126
            @airdream tried CRT Caligari and also your edited shader, both lad on my Pi 400 with Genesis/Megadrive Emu
            • airdream
              @roman126
              So maybe you have a preset that it cause the lag
              Do you have enabled rewind function? or "run ahead" in Retroarch? changed output resolution?
              roman126 1 Reply Last reply Reply Quote 0
              • roman126
                @airdream I will take a look, I`m running stock Recalbox with no Retroarch changes....
                airdream 1 Reply Last reply Reply Quote 1
                • airdream
                  @roman126
                  I am not sure if rewind function is by default or not
                  It's better to disable it
