    RGB DUAL EXTERNAL FAN PROBLEM
    rgb dual external fan
    • butoia
      butoia last edited by
      Hi to all, i've received my rgb dual and i'm testing it on my raspberry pi 4 + 3A 5v psu.
      I've noticed a problem on the headers for external fans. If i connect my fans on gnd and 3.3 or 5v the fans not move. I've tried to check with a tester and the are really low voltage on those headers. (0.6v on 3.3v and 0v on 5v) Anyone can help me about this issue?
      Thanks.
      • zetof
        zetof last edited by zetof
        hi,
        the fan start only if needed (if temperature > ~60°C) and stops if needed
        it is not real 3.3v and 5v pins
        zetof
        butoia 1 Reply Last reply Reply Quote 0
        • butoia
          butoia @zetof last edited by
          @zetof
          Have you a scheme to connect a standard fan (2 wires) i also have a 3 wires fan pwm, is possible use it?
          Thanks in advance!!
