    MUPEN64PLUS_NEXT Slow on rpi4 8gb
    hires textures n64 rpi4
    • jor2404
      jor2404 last edited by
      Hi
      I want to use MUPEN64PLUS_NEXT because I would like to play n64 games on my rpi4 8gb using hi-res textures packs.
      I play very well ti most of the n64 games using other cores, as I want to use high-res textures I need to use MUPEN64PLUS_NEXT but it is very slow and unplayable on my rpi4 8gb.
      Are there an specific configuration to run MUPEN64PLUS_NEXT with good performance on my rpi4?
      Or are there any other core different from MUPEN64PLUS_NEXT that can uses hi-res textures?
        Zing Global moderator Translator @jor2404 last edited by
        @jor2404 N64 is a heavy emulator, I don't recommend using high resolution textures on an Rpi4. I have an Rpi3 and I understand that although it is possible to play some N64 games on it, the hardware is not powerful enough to deliver optimal performance in all games. Rpi4 runs much better than N64, but still, the hardware is not powerful enough to be considered excellent.
        If you want excellent graphics quality and performance on the N64, you will need a more powerful computer than an Rpi4.
        Please use the forum's search tool and check if one of the many posts talking about N64 helps you:
        • https://forum.recalbox.com/search?term=n64&in=titlesposts&matchWords=all&sortBy=topic.lastposttime&sortDirection=desc&showAs=posts&page=1
