    Strange artifacts on text seen on games lists
    Themes & Interface
    strange artifacts text seen lists
    1641
    • Zoltrix
      Zoltrix last edited by
      Hi all,
      I'm running Recalbox 8.0.2 on a PC with an Nvidia GeForce GTX 1050 (connected to a 1080p TV). In the interface on the games list, for some reason there are some strange artifacts on the text. You can see on the first screen shot there are faint underlines, little thin lines next to the number "1", etc. Not a big deal, but was just curious on what the cause might be? As you can see in the second screenshot the text in other areas (game info, etc) is perfect.
        Zing Global moderator Translator @Zoltrix last edited by
        @zoltrix I'm not sure what it could be, but I'm guessing it's a problem with the resolution.
        You can try it on another TV to check, or you can try changing the resolution:
        https://wiki.recalbox.com/en/tutorials/video/display-configuration/external-screen-configuration
        But honestly, I think it's such a small problem that it might not be worth the time to invest in it.
        Zoltrix 1 Reply Last reply Reply Quote 0
        • Zoltrix
          Zoltrix @Zing last edited by Zoltrix
          @zing sorry I should have come back and added an update. Since this post I also tested the same build of Recalbox on a Raspberry Pi 4 connected to a 4k TV. So completely different hardware and TV. The same thing happens on that setup. It normally occurs once you have exited a game, and doesn't clear up until you restart Recalbox.
          It just looks a bit tacky on an otherwise fantastic looking interface.
          Since then I have moved my devices over to Batocera.
          I guess it's up to the developers if they think it's worth fixing or not.
          • jaswantraj
            jaswantraj Banned last edited by jaswantraj
            Hey Zoltrix,
            Good afternoon nice post here! Game developer only fixed this issue
            • Zoltrix
              Zoltrix @jaswantraj last edited by Zoltrix
              @jaswantraj said in Strange artifacts on text seen on games lists:
              Hey Zoltrix,
              Sorry don't follow.
                @zoltrix An update will be released soon, with several improvements, test when the new version is released.
