    [RESOLVED]Strange controller bug in recalbox's PiFBA
    recalboxs pifba
    2462
    • neko
      neko last edited by
      Conditions: - PiFBA in recalbox, any games. - Only the following two controllers I found is having this specific problem: PS4's DualShock4 or HORI Real Arcade Pro.3 Problem: The direction button and the Y button (square button) cannot be registered at the same time. If you are moving the character then press Y, the movement stop until you release button Y. If you are holding button Y, the character just cannot move at all. Isolation: I have a bunch of other controllers, like the DualShock3 and XBOX360 wireless controller, they all works fine. Tested RetroPie's PiFBA, no such problem found. Tested libretro FBA core on 3.2.9b2, no such problem found. I guess the problem is on recalbox's 4-players optimized PiFBA only. Any ideas? 😕
      • digitaLumberjack
        Releated to http://blog.recalbox.com/forums/topic/bouton-a-x360-filaire/, we're on it on the french side 😉
        • neko
          neko last edited by
          Its nice to see it being addressed, I am sitting back and wait for your good news 😄
          • digitaLumberjack
            Maybe the 3.2.9-beta5 corrected this bug, i need feedback 😉
            • neko
              neko last edited by
              Yes, it works perfectly now. Thanks a lot 😉
              • digitaLumberjack
                Héhé that's good to hear 🙂
