    Bluetooth Arcade Controller doesnt show up in controller config menu
    GamePad/GPIO/USB encoder
    bluetooth controller arcade atlegends
    • simbz23
      simbz23 last edited by
      Hi everyone,
      First time using Recalbox, amazing stuff! I have an issue though with an arcade stick. I have the Atlegends Gamer Pro, which is a bluetooth arcade controller. I am using the latest recalbox image on Pi 4. When I connect the arcade controller using the bluetooth menu, recalbox finds and connects successfully, and the controller also shows its connected.
      However, when I go to configure the controller and assign the buttons, Recalbox doesnt see it, so I can't even configure it. I have used the arcade stick with latest retropie successfully?
      Any help? 😞
        Zing Global moderator Translator @simbz23 last edited by
        @simbz23 Try a factory reset, available through the advanced settings menu, you will not lose any personal files, but you will lose all custom settings.
