    Why pc-fx only on rpi4?
    Testers's corner
    pc-fx rpi4
    • SsssQ
      SsssQ last edited by
      Really because it is 32 bits console with nec v810 cpu which is their own simple architecture based on pc engine. Pc fx ga emulation should work as well because it is now 64 bits
      • Alvin
        Alvin Banned @SsssQ last edited by Alvin
        @ssssq
        Maybe the "old" Pi's are not "powerful" enough to emulate this ?
        Do you think only because it's an old Console it can easily emulated ?
        For example: Do you think all your Dreamcast-Games
        https://forum.recalbox.com/topic/26566/chds-do-not-open-properly
        will run smoothly on your Raspberry Pi 3B+ ?
        I'm afraid they will not.
        I'm using a Pi 3B+ by myself and set the Overclock Option to "Extrem" (1500 Mhz) and even than not all Games will work.
        SsssQ 1 Reply Last reply Reply Quote 0
        • SsssQ
          SsssQ @Alvin last edited by
          @alvin i know but mednafen runs s m o o t h which allows you to emulate nec pce pcfx sega saturn(and about sega saturn theres yaba sanshiro which runs nice on rpi3b+).
          • Alvin
            @ssssq said in Why pc-fx only on rpi4?:
            Sorry, I don't get it.
            What do you want us to tell with this Post ?
            If I get it right you're running Sega Saturn on a Raspberry Pi 3b+ with Recalbox 8 ?
            How is this possible ?
            Look here:
            https://wiki.recalbox.com/fr/emulators/consoles/saturn/libretro-kronos
            https://wiki.recalbox.com/fr/emulators/consoles/saturn/libretro-mednafen_saturn
            (That’s the one you mentioned)
            https://wiki.recalbox.com/fr/emulators/consoles/saturn/libretro-yabasanshiro
            https://wiki.recalbox.com/fr/emulators/consoles/saturn/libretro-yabause
            It says none of the Sega Saturn Emulators in Recalbox 8 is compatible with a Raspberry Pi 3B+.
            So how did you get this to work ?
            And the Rest ?
            With "nec pce pcfx" you mean
            1. "NEC PC-Engine" and "PC-Engine CD" this works fine on my Pi 3B+ with Recalbox 6 using the "MEDNAFEN_SUPERGRAFX" Emulator-Core
            2. "NEC PC-FX" - This Emulator isn't running on a Raspberry Pi 3, because it's not compatible. Just look here:
              https://wiki.recalbox.com/en/emulators/consoles/pc-fx/libretro-mednafen_pcfx
              Maybe it's because the Pi 3B isn't "powerfull" enough to emulate this or is simply not compatible with this Emulator.
              Maybe someone from the "Recalbox-Team" will show up and explain it.
            • SsssQ
              alvin, i just forced retroarch using console hack and installed mednafen and yaba sanshiro cores.
              content did not list, so it could be opened with libretro w/o any args
