    Resolution problem with Recalbox 8 on a 4K Samsung
    recalbox samsung
    • Tormentor667
      Tormentor667 last edited by
      Dear developers and users, maybe someone can help me. I am having problems with the resolution of my Recalbox 8 (on a Pi4) attached to my Samsung 4K monitor.
      Instead of being stretched to the max of the screen, I get black bars on the top and bottom of the screen and Recalbox is only displayed on some kind of a 21:9 resolution instead of using my 16:9 screen. It’s not cropped but instead the becels are stretched or drawn wider.
      I would like to use the full screen for Recalbox though. What can I do?
      Bonus question: Where can I deactivate Becels?
      Thanks kindly,
      Best regards
      Dan
      • Alvin
        Alvin Banned @Tormentor667 last edited by
        @tormentor667
        Maybe this will help:
        https://wiki.recalbox.com/en/tutorials/video/display-configuration/complete-video-configuration-guide
        To disable Overlays (Bezels) look here:
        https://wiki.recalbox.com/en/basic-usage/features/overlays
        Tormentor667 1 Reply Last reply Reply Quote 0
        • Tormentor667
          Tormentor667 @Alvin last edited by
          @alvin thanks kindly for your links, but unfortunately I don't get it to work. I've tried what has been suggested in the config guide and also found the right number for my 4K display but I don't get the right result.
          I've found something out though:
          As you can see, the tv screen itself has a picture ratio of 16:9, the displayed part from Recalbox has a video ratio from 21:9 though. Makes sense to display the "21:9" image in the middle of the "16:9" screen - yes, but from Recalbox, the tv should get a 16:9 signal but it gets a 21:9 one (tried to change that in my Samsung menue but it always states, that the signal is 21:9 and not 16:9).
          How can I force the output from Recalbox to be 16:9?
          Best regards,
          Dan
          EDIT
          I got it fixed somehow. Changing the HDMI port on my tv made it work... maybe this helps someone else as well 🙂
