    transfer saves
    transfer saves
    • Ivoson
      Ivoson last edited by
      I'm trying to transfer save files from my computer over to my recalbox build. For instance I'm trying to transfer an SNES save file extension .srm it works and loads fine on my computer but will not load on my recalbox. Is there anyway to transfer my save files from my computer to recalbox?
      Thanks!
        Zing Global moderator Translator @Ivoson last edited by
        @ivoson If you don't know how to access Recalbox via network:
        • https://wiki.recalbox.com/en/basic-usage/file-management
        • https://wiki.recalbox.com/en/tutorials/system/access/network-access-winscp
        If you know, transferred and it didn't work, then most likely the problem is the emulators version that must be different. If that's the problem, there's nothing you can do.
