    Bug and glitches on Raspberry PI zero v1.3
    glitches zero v1.3
    • heldegar
      heldegar last edited by
      Hello i just received my Raspberry pi zero v1.3
      I installed the latest update of Recalbox, but i keep getting those glitches, like many text replaced by white square and things like on the picture below. Do you got any clue to make it works ? thank you
      Zing Alvin 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @heldegar last edited by
        @heldegar Please test with a clean install of the latest official version of Recalbox, with some game that comes pre-installed (don't change any settings, just to test).
        If it works, it's some customization you did.
        If it doesn't work, try it on another TV, and test it with another HDMI cable and post the result here.
        • Alvin
          Alvin Banned @heldegar last edited by Alvin
          @heldegar
          The Raspberry Pi Zero only has 512 MB as RAM, the Pi 3 for example has 1 GB RAM.
          So on the Pi Zero I would suggest:
          • Do not use a video output in 1080p. Forcing the 720p in the recalbox-user-config.txt is the best way to keep overall resolution "low"
          • Disable the Webmanager (it takes too much ram for now)
          • Keep the original recalbox theme
          • Keep the number of active system low
          • Do not use fullsets
