    Mame2015 games exiting on startup with Non-Zero exit code 245
    Emulator Arcade/PC/Console
    mame2015 exiting startup non-zero code 245
    • dreasgrech
      dreasgrech last edited by
      (8.0.2-Electron PI400) I'm having trouble running ROMs with the Mame2015 core. I'm using a v0.160 romset for this core, and have tried with both a full non-merged set and a full T7Z-Merged set but I can't get any ROM to run with this core. I have tried manually setting the Mame2015 core on a game in the EmulationStation UI but I also have a .recalbox.conf fie in my Mame2015 directory with:
      mame.emulator=libretro
      mame.core=mame2015
      I have verified these ROMs by installing MAME2015 v0.160 on my Windows machine and the ROMs run fine in there. But when running the ROMs in Recalbox, I get the Recalbox logo, then a black screen, then the Recalbox logo again and then back to the games list, and this happens for all the ROMs in this directory.
      These are the logs that occur when launching a ROM, with Mame2015 this one wrally.zip:
      [2022/03/09 00:16:32.650] (INFO ) : [Run] Launching game...
      [2022/03/09 00:16:32.651] (INFO ) : [Input] Configure emulators command :  -p1index 0 -p1guid 030000005e0400008e02000005010000 -p1name "Xbox 360 Controller" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 13 -p1devicepath /dev/input/event1
      [2022/03/09 00:16:32.651] (INFO ) : [Run] Controllers config :  -p1index 0 -p1guid 030000005e0400008e02000005010000 -p1name "Xbox 360 Controller" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 13 -p1devicepath /dev/input/event1
      [2022/03/09 00:16:32.651] (INFO ) : [AudioManager] Shutting down SDL AUDIO
      [2022/03/09 00:16:32.811] (INFO ) : [Run] Command: python /usr/bin/emulatorlauncher.pyc  -p1index 0 -p1guid 030000005e0400008e02000005010000 -p1name "Xbox 360 Controller" -p1nbaxes 4 -p1nbhats 1 -p1nbbuttons 13 -p1devicepath /dev/input/event1 -system mame -rom /recalbox/share/roms/mame/Mame2015/wrally.zip -emulator libretro -core mame2015 -ratio auto
      [2022/03/09 00:16:32.816] (INFO ) : [Pad2Keyboard] No pad2keyb configuration.
      [2022/03/09 00:16:32.818] (INFO ) : [Hardware] Start in-game Hardware processes
      [2022/03/09 00:16:34.808] (INFO ) : [Hardware] Stop in-game Hardware processes
      [2022/03/09 00:16:34.812] (WARN!) : [Run] Non-Zero exit code 245 !
      [2022/03/09 00:16:35.655] (INFO ) : [Renderer] Initial resolution: 1920x1080
      [2022/03/09 00:16:35.655] (INFO ) : [Renderer] Creating surface...
      [2022/03/09 00:16:35.655] (INFO ) : [Renderer] Trying Resolution: 1920,1080
      [2022/03/09 00:16:35.748] (INFO ) : [Renderer] Created window successfully.
      [2022/03/09 00:16:35.765] (INFO ) : [Renderer] Activating vertical sync'
      [2022/03/09 00:16:35.766] (INFO ) : [Renderer] Normal VSync' activated.
      [2022/03/09 00:16:36.674] (INFO ) : [AudioManager] SDL AUDIO Initialized
      [2022/03/09 00:16:36.674] (INFO ) : [InputManager] Initialize SDL Joystick system
      [2022/03/09 00:16:36.674] (INFO ) : [InputManager] Joystick count: 1
      [2022/03/09 00:16:36.674] (INFO ) : [InputManager] Lond configuration for Joystick #: 0
      [2022/03/09 00:16:36.676] (INFO ) : [Input] Added joystick Xbox 360 Controller (GUID: 030000005e0400008e02000005010000, Instance ID: 3, Device Index: 0, Axis: 4, Hats: 1, Buttons: 13)
      [2022/03/09 00:16:36.676] (INFO ) : [InputManager] Refresh joysticks
      As you can see, the game seems to be exiting immediately with Non-Zero exit code 245 ! but I cannot figure out why this is happening.
      • dreasgrech
        I have now tried the same scenario, using the same romset and everything, but on a fresh Recalbox installation, and the Mame2015 roms worked fine.
        So it seems like for some reason, my Mame2015 core got corrupted or something on my original installation.
        I'm currently comparing the differences between my previous install and my fresh install but I haven't been able to spot anything that is Mame2015 related in the deltas.
