    MAME roms not showing up
    Emulator Arcade/PC/Console
    mame roms showing
    6988
    • TSL2018
      TSL2018 last edited by
      Hello! I have the downloaded Mame Romset 223 and I transferred via ssh over a rom to the MAME folder but it's not showing up in my list. Will recalbox recognize it?
      Alvin Zing 2 Replies Last reply Reply Quote 0
      • Alvin
        Alvin Banned @TSL2018 last edited by
        @tsl2018
        Did you refresh your Gamelist ?
        Main Menü -> UI Settings -> and then on the Bottom (maybe you have to scroll down) -> "Refresh Gamelist"
        TSL2018 1 Reply Last reply Reply Quote 0
        • TSL2018
          TSL2018 @Alvin last edited by
          @alvin Yes I tried that a few times. Still not showing up besides the included ones that were there.
            Zing Global moderator Translator @TSL2018 last edited by
            @tsl2018
            Mame Romset 223
            https://wiki.recalbox.com/en/tutorials/games/generalities/isos-and-roms/romsets-for-recalbox
            • TSL2018
              TSL2018 @Zing last edited by
              @zing Thanks! I tried the lower rom sets and still not showing. Not sure if its with my build. I am using a Pi 4 2gb.
                Scavy Global moderator @TSL2018 last edited by
                @tsl2018 hi
                Check if your gamelist option is set on "Gamelist only" or not.
                If so, disable this option, delete the current gamelist in your mame folder and check a new time.
                Your roms are .zip roms ?
