    Amig Forever roms don't match Md5 checksums
    Emulator Arcade/PC/Console
    amig forever roms dont match md5 checksums
    • ddtackett
      ddtackett last edited by
      Hello,
      I am trying to use the roms from the Amiga Forever site and when I copy them to the BIOS folder using the proper names it shows the file is there, but the Md5 checkums don't match what is expected. Is there a way for me to disable MD5 checks?
        Zing Global moderator Translator @ddtackett last edited by
        @ddtackett
        Sorry, but doing this is pointless.
        The MD5 check is there to make sure you are using the correct BIOS, if you are getting an alert it is because you have the wrong BIOS, what you need to do is use the correct BIOS.
        "Cheating" the system by bypassing the BIOS check will not solve the problem of using the wrong BIOS: the emulator may not work, games may not run, or run slowly, etc.
        • https://wiki.recalbox.com/en/basic-usage/features/bios-manager
        • https://youtu.be/ZhdgY_2_SIQ?t=1819
        ddtackett 1 Reply Last reply Reply Quote 0
        • ddtackett
          ddtackett @Zing last edited by
          @zing Thanks for responding. I legally own the BIOS files. Where can I get roms with the correct MD5 checksums?
            @ddtackett Sorry, but BIOS and ROMS are copyrighted, that's why they are not distributed along with the Recalbox image, and for the same reason requesting or distributing this type of content is prohibited here on the forum, you need to get them yourself.
