    Kodi no longer included?
    MediaCenter & Dualboot
    kodi longer included
    • tuxophil
      tuxophil last edited by
      Hi,
      I was on a rather old recalbox setup, so I've decided to migrate to 8.0.1 (RPi2). To my astonishment I can't find Kodi anywhere!? It's neither listed in the main menu nor does it start when I press X on my gamepad.
      I'm a bit perplex. Is Kodi even included or has it been removed in 8.0? (That would be a huge change for the worse.)
      Do I have to enable it manually somehow?
      Otherwise 8.0 seems to be a huge leap forward when compared to my ancient (many years old) recalbox that I'm trying to replace. (Fortunately I do have a backup. Kodi is a necessity for my use case.)
      tuxophil 1 Reply Last reply Reply Quote 0
      • tuxophil
        tuxophil @tuxophil last edited by tuxophil
        Hm, I've just found a post that says, in essence, that for most Raspberry Pi systems, Kodi is no longer available:
        https://forum.recalbox.com/post/174579
        To be honest I'm a bit shocked. Is there anywhere a download for the most recent RPi2 image with Kodi still included? (Oh, and I'd suggest to prominently document such an important breaking change.) My old setup that I wanted to upgrade (on the same hardware which is perfectly fine) dates from 2016. On another RPi2 I have libreelec with a much more modern Kodi. In fact that's the reason I wanted to upgrade in the first place: finally have a less dated UI in Kodi.
