    Change NES Emulator
    Emulator Arcade/PC/Console
    nes
    • Lightbringer1982
      Lightbringer1982 last edited by
      Hi,
      i am using Recalbox Dragonblaze 6.1.1 on Raspberry 3b.
      I want to change the NES Emulator in the Recalbox System.
      How can i do this? As far is i know the random installed Emulator is Libretro. how can i install another, which emulators will work in recalbox (JNES?) and how can i install them easily and set them as random? I didnt found a manual or a hint in the Forum.
      Thanks.
        Zing Global moderator Translator @Lightbringer1982 last edited by
        @lightbringer1982 The forum does not support outdated versions of Recalbox, and you are using a very old version.
        Also, there is no function to choose an emulator at random, what you can do is manually change the emulator in the game options.
        You can't install anything on Recalbox either, regardless of version, you need to choose one of the available emulators.
