    recalbox x86 can't get it full screen on 1080p monitor
    recalbox x86 cant full
    • martyn22
      martyn22 last edited by martyn22
      Whatever I do i have black borders on each side of my monitor... help please. Im running it from my pc x86 build
      cesartaqui 1 Reply Last reply Reply Quote 0
      • cesartaqui
        cesartaqui @martyn22 last edited by
        @martyn22 Recalbox comes standard with the default setting of 4/3. To switch to full screen, go to "game options" > "screen options" and change the resolution to 16/9. This solves the problem.
        If it's already set to that aspect ratio, make sure the aspect ratio IN ADVANCED CORE SETTINGS is 16/9. (advanced settings > advanced emulator settings > choose emulator and check).
        If you're using recalbox on a smart TV, check your TV's display settings. This varies from TV to TV.
