    recalbox unconfigured
    Your recalbox
    • lolo2020
      lolo2020 last edited by
      Good morning! Using my recalbox on raspberry pi2 I had a big problem. While it was turning on, no video came out and I decided to turn it off.
      When I reconnected it I realized that I lost the intro that I added, the recalbox.conf file was reinstalled, remap files were deleted as if recalbox was reinstalled. Why is this happening? How can I avoid it? I am using a raspberry pi2 with recalbox 8.0.1. It is very frustrating to start again.
        Zing Global moderator Translator @lolo2020 last edited by
        @lolo2020 I can only imagine that you had a file corruption problem, which could be caused by a hardware problem, or because you force shut down at a time when the system was doing some writing to some main boot file.
        In either case, I don't know what I can help with, as in no system is it recommended to forcibly turn off the power (I understand you did this because the system wouldn't start, but maybe you should have waited a little longer), or, if it's a hardware issue, like some SD card corruption, you'll end up experiencing it again randomly if you don't swap the SD card for another one...
        lolo2020 1 Reply Last reply Reply Quote 0
        • lolo2020
          lolo2020 @Zing last edited by
          @zing thank you! I will test everything again!
