    Problème Freeze Recalbox.
    recalbox
    • SuperJuju
      SuperJuju last edited by
      Bonjour tout le monde.
      J'ai des soucis de freeze dans le menu de Recalbox depuis la dernière MAJ. De temps en temps j'ai l'écran qui se fige quand je lance un jeu ou que je change de fond d'écran par exemple mais ça me le fait que dans le menu en jeu je n'ai aucun problème.
      Je suis sous Pi3 B+ dernière version si quelqu'un a une idée merci à vous.
      • fredisback81
        fredisback81 last edited by
        Hi,
        I have the same problem, Pi 3 B+, on newest version (RB 8.0.2), freezing incidents in menu, game menus or in-game.
        Thanks & Regards,
        fredisback81
        RPi 3b+ with Nespi Case - Recalbox v8
        • ruidoquattro
          ruidoquattro last edited by
          Hi
          I have some problems too. In my case, it happens on RPI zero 2 on GPi case, after boot video, the loading image starts doing some weird stuff. I've recorded a video to show you, because it would be hard to explain what's going on... https://www.youtube.com/watch?v=d2uSG4D7QQw
          Funny thing's you can control the menu, but you can't see what's selected. The background music works perfectly and you can see a small change on the screen when you press the menu button, so it has to be something related to display, 'cause everything else is working...
          I don't know what to do now...
            Scavy Global moderator @ruidoquattro last edited by
            @ruidoquattro I guess it's a known issue.
            RPi0 v2 is as powerfull as a RPI3 card. It's required more power than the Pi0 v1. I guess you're using batteries. They are not powerfull enough.
            Re install and use your GPicase with RPi0 v2 using the power cable (connected to a USB port). It should work correctly ^^
            SuperJuju 1 Reply Last reply Reply Quote 0
            • SuperJuju
              SuperJuju @Scavy last edited by
              @scavy Bonsoir vous avez des retours concernant les freezes sur les menu pour les PI3? Merci.
