    8bitdo pro 2 wired is not supported?
    GamePad/GPIO/USB encoder
    8bitdo wired supported
    • degradilla
      degradilla last edited by degradilla
      I bought 8bitdo pro 2 wired for my recalbox, i read on recalbox website that pro 2 is supported but I did not pay attention that there is a difference between the wired and wireless version, so i bought the wired version, maybe someone could connect this gamepad or maybe you know where i can find info how to do it?
      sorry for my English(
      Zing Sven 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @degradilla last edited by
        @degradilla
        https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/8bitdo-on-recalbox
        • Sven
          Sven @degradilla last edited by
          @degradilla
          Maybe it helps?!?
          8BitDo Pro 2 Wired don't have the "Mode Switch" to select type of pad like the wireless pad.
          The default mode ist S-Input for Nintendo Switch / XBox Mode.
          Before you connect the controller, hold B-button and connect it.
          At this time it switches to D-Input for Android-Mode.
          After this Recalbox can recognize the controller named "8BitDo Pro 2".
          But you have to do this every time you start Recalbox.
          For Windows press X-button for X-Input, that it.
          https://support.8bitdo.com/faq/pro2-wired-controller.html
          RottenRotz 1 Reply Last reply Reply Quote 0
          • RottenRotz
            RottenRotz @Sven last edited by
            @Sven said in 8bitdo pro 2 wired is not supported?:
            @degradilla
            Maybe it helps?!?
            Sorry for necro.I have the exact same problem,but after updating controller firmware to 1.03,the system reckognizes 8bitdo pro 2 wired everytime and works in game from very start,no need to unpug and plugin holding B button everytime you start recalbox.But there is another problem and that is,after configuring buttons a dozen of times they are all randomly scrambled.Most of the times the system doestn see anything assigned to buttons A and B for instance.Ive tested this in Marvel Super Heroes.While my Logitech F310 works without problems,even after configuring buttons in the way that punching is on A and B,the system randomly sets them to L1 or R2 or something.Ive tried setting drivers to system but no avail.Has anyone have some suggestions?
