    Odroid go super, usb flash drive
    odroid usb flash
    989
    • Outsoba
      Outsoba last edited by
      My odroid doesnt see the usb drive, i have it formatted in fat32. I tried other drives, and nothing works, usb does work because i checked with a controller and it works.
      • Aldébaran
        Aldébaran @Outsoba last edited by
        Hello, @outsoba
        You can't use USB to flash Recalbox on Odroid Go Advance/Super. You have to flash Recalbox on a micro SD card.
        Outsoba 1 Reply Last reply Reply Quote 0
        • Outsoba
          Outsoba @Aldébaran last edited by Outsoba
          @aldébaran I want to use it to store roms and saves on it.
          Outsoba Pitch64 2 Replies Last reply Reply Quote 0
          • Outsoba
            Outsoba @Outsoba last edited by Outsoba
            @outsoba should the system menu show the option for external storage, also when no USB is plugged?
            There is no option there.
            • Pitch64
              Pitch64 Staff @Outsoba last edited by
              @outsoba storing on USB is not compatible with the sleep mode of the Odroid Go Super.
              Next release? Soon™
              • Outsoba
                Outsoba @Pitch64 last edited by
                @pitch64 ok, thanks.
