    XArcade Tankstick
    GamePad/GPIO/USB encoder
    xarcade tankstick
    • Chuck_Gee
      Chuck_Gee last edited by
      Greetings everyone. New to this, but been doing classic arcade via MAME and a PC for a long time. I have recalbox up and running on my new Pi 4 and working with PS3 game controllers. Cannot get it to recognize my Tankstick and trackball. It does work with Retropie via a driver I've downloaded, so it's clearly some setting I'm missing for recalbox.
      I did read the thread I've linked below, but it seems a little stale as the version I'm on is 8.0. Is this still the correct procedure? I downloaded the pi 4 file at the “tester” topic, and I think I’m supposed to rename it “xarcade2jstick-rpi4” from the 25 jumble of characters the file is currently named, but I am not certain.
      I also have no experience with putty so I'm a little gun shy. If I could get some direction, I'd greatly appreciate it.
      https://forum.recalbox.com/topic/22492/tester-wanted-xarcade-tankstick?_=1640804869909
      Chuck
        Zing Global moderator Translator @Chuck_Gee last edited by
        @chuck_gee This problem should have already been solved, and it should only be necessary for the user to put it in mode 4.
        BUT... I saw that users mentioned the need to do this manipulation not long ago:
        https://forum.recalbox.com/topic/23849/x-arcade-dual-stick-non-reconnu/12
        I don't have this joystick and I can't test if there really is still a need for this manipulation, but yes, the post instruction asks to rename the file, and copy it to the recalbox/share/system folder, and then, with Recalbox turned on, connect via SSH and execute the commands:
        mount -o rw,rmount /
        cp /usr/bin/xarcade2jstick /usr/bin/xarcade2jstick-old
        cp xarcade2jstick-rpi4 /usr/bin/xarcade2jstick
        chmod 755 /usr/bin/xarcade2jstick
        See if this helps:
        • https://wiki.recalbox.com/en/tutorials/system/access/root-access-terminal-cli
        • https://wiki.recalbox.com/en/tutorials/system/access/network-access-winscp
        • https://youtu.be/Bt4aHZ2Xo2g
        Chuck_Gee 1 Reply Last reply Reply Quote 0
        • Chuck_Gee
          Chuck_Gee @Zing last edited by
          @zing This clarifies things tremendously. I will try later today and report back my results. Thanks very much.
          • Chuck_Gee
            Chuck_Gee @Chuck_Gee last edited by Chuck_Gee
            OK, gave it a try. I uploaded xarcade2jstick-rpi4 file and switched the Tankstick mode to 4. I'm now getting an error message after I login to root:
            login as: root
            root@xxx.xxx.xx.xxx's password:
            mount: can't find / in /etc/fstab
            From my cursory research, this seems to be a partition thing. Any guidance?
              @chuck_gee Test with the command below and see what happens:
              mount -o remount,rw /
