    8bitDo Pro 2
    GamePad/GPIO/USB encoder
    8bitdo
    1745
    • Shingohky
      Shingohky last edited by
      Bonsoir à tous
      j'ai remarqué sur le Wiki Recalbox consacré aux pads 8bitdo que la manette Pro+ version 2 ne figure pas dans la liste des compatibilités ?????
      Sachant que j'ai des soucis sous Retroarch avec ce modèle !!!!!!! il y a t-il un futur correctif de prévu ???? Merci d'avance des retours 🙂
      • rebok232
        rebok232 last edited by
        @shingohky please don't use French in english formum. If you want use French go to French recalbox forum
        Translated message:good evening everyone
        I noticed on the Recalbox Wiki dedicated to 8bitdo pads that the Pro + version 2 controller is not in the list of compatibilities ?????
        Knowing that I have problems under Retroarch with this model !!!!!!! is there a future fix planned ???? Thanks in advance for feedback 🙂
        Shingohky Mattcristal 2 Replies Last reply Reply Quote 0
        • Shingohky
          Shingohky @rebok232 last edited by
          @rebok232
          I'm sorry if I posted on the wrong forum, it's an unintentional error. If a moderator wants to move my topic to the correct section. Thanks in advance 🙂
          • Mattcristal
            Mattcristal @rebok232 last edited by
            @rebok232 hello, I just bought a 8bitDo Pro 2 today and I was testing it with the Recalbox 8.0. I was able to make it work by connecting it with the cable. Yet, I had some issues with some games where it seems that some buttons were not working very well. Just wanted to share my experience.
            rebok232 1 Reply Last reply Reply Quote 0
            • rebok232
              rebok232 @Mattcristal last edited by
              @mattcristal I'm not expert i'm brginner
              I'cant helo you
                Scavy Global moderator @Shingohky last edited by
                @shingohky hello
                I'm using a 8BitDo SN 30 pro + and it works fine.
                Is it the same model ? What is your firmware ?
                Shingohky 1 Reply Last reply Reply Quote 0
                • Shingohky
                  Shingohky @Scavy last edited by
                  @scavy Hello Scavy
                  No it's not the same model,i have a 8BitDo SN 30 pro + and it works fine but I have too the newest model the 8BitDo pro 2 with the firmware v1.01 it works very well in Emulstation but when I run a game which uses a Retroarch core, it is no longer detected and I have to turn it off then on again to make it operational again. Otherwise, you could move this post to the French forum it will be easier for me to converse in this language 😉
                    @shingohky i see with the devs...
