    (SOLVED) Atari ST - How to modify the .st file for direct start in Emulator
    solved atari modify direct start
    • abunille
      abunille last edited by
      Hi all, some Games starts directly, but some games goes in the Atari menu, i must go to "DISKSTATION" and double press on xxx.prg. Someone here to tell me how i can modify the file for direct start?   greetings   EDIT: Ok, i have solved my problem. For all who has the same problem: I open the .st file with "MSA-Converter" Then i create an Folder named "AUTO" und put the xxx.prg in there. The xxx.prg file which was in root of the .st i have delete. Then save, done 🙂 I have tested with 2 .st files and it work for me. I give no guarantee greetings
