    [GPi Case] FBA2X - aspect ratio help
    [gpi case] fba2x aspect ratio help
    1516
    • Lumpy
      Lumpy last edited by
      Hi all. Just want to say Recalbox is amazing on the GPi! However, I have a problem with FBA2X. It is a brilliant emulator for this little low power device, but it's a little bit squished on the screen. Is there a way to fix this?
      I should add I'm using the latest 7.2.2 Reloaded release for the Pi Zero/Pi 1 on the GPi Case. I Know there's the newer Pi Zero 2 but I haven't got that one. Thanks all.
      Lumpy 1 Reply Last reply Reply Quote 0
      • Lumpy
        Lumpy @Lumpy last edited by
        I should also add that I am referring only to CPS roms. On Neo Geo it runs fine. It's only on CPS that the display shows borders at the top and bottom, effectively squashing the display. Thanks.
          Zing Global moderator Translator @Lumpy last edited by
          @lumpy
          https://wiki.recalbox.com/en/tutorials/video/display-configuration
          • Lumpy
            Lumpy @Zing last edited by
            @zing
            Thanks for this. Sadly it didn't work. 😞
            It looks like there's a setting in fba2x.cfg called maintain_aspect_ratio. This is always set to 1. I've tried to change this but it gets overridden each time I launch the emulator. Could you advise where I'd need to change this so there's no override? Many thanks for your help. 🙂
            Lumpy Zing 2 Replies Last reply Reply Quote 0
            • Lumpy
              I mean, it might not be this that is causing the issue, but it's got to be worth a try. 🙂
                @lumpy
                I don't have a Gpi case and I can't test it, have you read the documentation for this emulator?
                https://wiki.recalbox.com/en/emulators/consoles/neo-geo/fba2x
