    [7.3-Beta29][FORK] Controler issue in emulators
    GamePad/GPIO/USB encoder
    controler issue
    3134
    • delferius
      delferius last edited by delferius
      Hi everyone!
      I have build my own recalbox version for testing my developpement from the master branch.
      I haven't any input in retroarch emulators, otherwise I haven't any problem on emulationstation.
      It's the same problem with my openJVS and my 8bitdo SF30 controllers.
      Someone have test the last beta on odroidxu4 and have the same issue?
      MR:
      https://gitlab.com/recalbox/recalbox/-/merge_requests/2020
      davidb2111 1 Reply Last reply Reply Quote 0
      • davidb2111
        davidb2111 Staff @delferius last edited by
        Hi @delferius
        Thanks for the MR. Please just be aware that the MR will not be in 7.3 (i.e 8.0) as it is in freeze stage. Just keep at aligned with master branch.
        Regarding the controller issue, I think I don't understand: does it work well in ES and not in retroarch for both 8bitdo controllers and openJVS?
        also, how does openjvs controllers appears in the system ? you could use sdl2 -jstest -l to list detected controllers and sdl2-jstest -t X where X is the id of your controller to test buttons.
        David
        delferius 1 Reply Last reply Reply Quote 0
        • delferius
          delferius @davidb2111 last edited by delferius
          Hi @davidb2111 and thanks for your help!
          My controllers are correctly detected by jstest and the input events works for both (openjvs_a1p1/openjvs_a1p2):
          # sdl2-jstest -l
          error: failed to read gamecontrollerdb.txt: Invalid RWops
          Found 3 joystick(s)
          Joystick Name:     '8Bitdo SF30 Pro'
          Joystick Path:     '/dev/input/event4'
          Joystick GUID:     05000000c82d00000061000000010000
          Joystick Number:    0
          Number of Axes:     4
          Number of Buttons: 16
          Number of Hats:     1
          Number of B***s:    0
          GameControllerConfig:
            Name:    '8BitDo SF30 Pro'
            Mapping: '05000000c82d00000061000000010000,8BitDo SF30 Pro,a:b0,b:b1,back:b10,        dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b2,leftshoulder:b6,leftstic        k:b13,lefttrigger:a5,leftx:a0,lefty:a1,rightshoulder:b7,rightstick:b14,righttrig        ger:a4,rightx:a2,righty:a3,start:b11,x:b3,y:b4,hint:SDL_GAMECONTROLLER_USE_BUTTO        N_LABELS:=1,'
          Axis code  0:    0
          Axis code  1:    1
          Axis code  2:    2
          Axis code  3:    5
          Button code  0:   304
          Button code  1:   305
          Button code  2:   306
          Button code  3:   307
          Button code  4:   308
          Button code  5:   309
          Button code  6:   310
          Button code  7:   311
          Button code  8:   312
          Button code  9:   313
          Button code 10:   314
          Button code 11:   315
          Button code 12:   316
          Button code 13:   317
          Button code 14:   318
          Button code 15:   319
          Hat code  0:   16
          Joystick Name:     'openjvs_a1p1'
          Joystick Path:     '/dev/input/event2'
          Joystick GUID:     000000006f70656e6a76735f61317000
          Joystick Number:    1
          Number of Axes:     2
          Number of Buttons:  8
          Number of Hats:     0
          Number of B***s:    0
            missing (see 'gamecontrollerdb.txt' or SDL_GAMECONTROLLERCONFIG)
          Axis code  0:    0
          Axis code  1:    1
          Button code  0:   256
          Button code  1:   257
          Button code  2:   258
          Button code  3:   259
          Button code  4:   260
          Button code  5:   261
          Button code  6:   262
          Button code  7:   263
          Joystick Name:     'openjvs_a1p2'
          Joystick Path:     '/dev/input/event3'
          Joystick Number:    2
          Number of Axes:     2
          Number of Hats:     0
          Number of B***s:    0
          Axis code  0:    0
          Axis code  1:    1
          Button code  0:   256
          Button code  1:   257
          Button code  2:   258
          Button code  3:   259
          Button code  4:   260
          Button code  5:   261
          Button code  6:   262
          Button code  7:   263
          #sdl2-jstest -t 1
          Joystick Number: 0
          Axes  2:
             0:      0  [        #        ]
             1:      0  [        #        ]
          Buttons  8:
             0: 0  [ ]
             1: 0  [ ]
             2: 1  [#]
             3: 0  [ ]
             4: 0  [ ]
             5: 0  [ ]
             6: 0  [ ]
             7: 0  [ ]
          Hats  0:
          B***s  0:
          Press Ctrl-c to exit
          Everything is ok on emulationstation, I can easily remap buttons and navigate with all my controllers but when I start any emulators nothing response.
          • davidb2111
            @delferius
            Oh, understood. Could you please share the file /recalbox/share/system/.emulationstation/es_inputs.cfg ?
            • delferius
              @davidb2111 I have only forward the interessant part of the file below. Tell me if you want the entire file.
              	<inputConfig type="joystick" deviceName="openjvs_a1p1" deviceGUID="000000006f70656e6a76735f61317000" deviceNbAxes="2" deviceNbHats="0" deviceNbButtons="8">
              		<input name="left" type="axis" id="0" value="1" code="0" />
              		<input name="down" type="axis" id="1" value="-1" code="1" />
              		<input name="right" type="axis" id="0" value="-1" code="0" />
              		<input name="up" type="axis" id="1" value="1" code="1" />
              		<input name="r1" type="button" id="5" value="1" code="261" />
              		<input name="l1" type="button" id="2" value="1" code="258" />
              		<input name="y" type="button" id="0" value="1" code="256" />
              		<input name="x" type="button" id="1" value="1" code="257" />
              		<input name="b" type="button" id="3" value="1" code="259" />
              		<input name="a" type="button" id="4" value="1" code="260" />
              		<input name="hotkey" type="button" id="7" value="1" code="263" />
              		<input name="select" type="button" id="7" value="1" code="263" />
              		<input name="start" type="button" id="6" value="1" code="262" />
              	</inputConfig>
              	<inputConfig type="joystick" deviceName="openjvs_a1p2" deviceGUID="000000006f70656e6a76735f61317000" deviceNbAxes="2" deviceNbHats="0" deviceNbButtons="8">
              	</inputConfig>
              I also try a full build with a clean output folder, in case it get corrupted...
              • davidb2111
                @delferius said in [7.3-Beta29][FORK] Controler issue in emulators:
                	</inputConfig>
                	</inputConfig>
                Do you skip d-pad and fill only joystick section ?
                • delferius
                  @davidb2111 No I skip joystick (analog) part and fill dpad for openjvs a1p1/openjvs a1p2 controllers.
                  For 8bitdo SF30 I assign all inputs and it's the same issue.
                  • delferius
                    delferius @delferius last edited by
                    Fresh and clean build test of this morning. Always the same issue.
                    I make my current build from the master, I will try from 7.3-Beta 30.
                    • delferius
                      @davidb2111
                      Finally when I disable my openJVS driver, all work perfect, my emulate controller seem to enter in conflict with something.
                      For information, I had no issues with my driver on the 6.1.1 forked release :/.
                      • delferius
                        @davidb2111
                        When I select "Game library driver" instead of "automatic" driver in the ES controller settings my openJVS controller work as expected but not the 8bitdo SF30 controller. What exactly happen on usage of one or the other driver settings?
                        • davidb2111
                          @delferius
                          I don't remember well. I think it's how the controller is processed:
                          • through SDL
                          • through udev
                          • delferius
                            @davidb2111 Is there a way to solve my problem? In the 6.1.1 version all worked fine. What's exactly changed behind this driver setting?
                            • davidb2111
                              @delferius
                              There are so many components that changed since 6.1.1 I can't enumerate all of them: kernel, sdl, EmulationStation, python, ...
                              I did not catch the exact problem you have and I don't have that type of controller. This makes the resolution of the problem twice as hard, sorry.
                              First, what is OpenJVS? And how do you connect it to the card ?
                              • delferius
                                delferius @davidb2111 last edited by Zing
                                @davidb2111
                                First, thanks for your help.
                                OpenJVS is a python module to emulate Joypad from RS485 JVS arcade protocol.
                                My module talk to the arcade IO-board throught Serial connection and trigger inputs over uinput virtual joypad device.
                                You can find the source code over here:
                                https://gitlab.com/gaper-private/openjvs/-/tree/python3
                                All work perfect on emulation station. But when I want to used OpenJVS controller on emulator, I must select "Game library driver" instead of "automatic" driver in the ES controller setting.
                                I use 4 different joypads on my system:
                                8bitdo SF30
                                8bitdo M30
                                openjvs_a1p1
                                openjvs_a1p2
                                8bitdo controllers seem to work only with "System driver" and OpenJVS with "Game library driver". So I can't use 8bitdo and OpenJVS controllers at the same times (to play ninja turtle with 4 player for example).
                                To reproduce the issue you can use a python script with uinput library. If you want I can write it for you.
                                • delferius
