    Wheres the Roms?
    wheres roms
    4172
    • borg357
      borg357 last edited by
      Bought a new Pi4, downloaded RecalBox 7.22, imaged my flash, installed the flash, boots up.. configure the joystick. EVERYthing works.
      I use my browser and go to http://<recalboxIP>. Check configs..
      I go to ROMS... Where I can't find a single ROM??
      Lets say I want to delete a ROM.. Where do I go to delete that ROM??
      How come there is NO FTP access, or Network access, only a webpage??
      I haven't been in this scene for a while, and it looks like Recalbox has made a bunch of nice inprovements since.. But where are the ROMS??
      thanks
      -Richard
        Scavy Global moderator @borg357 last edited by
        @borg357 hello
        pre-installed roms can't be deleted. However, in the menu you'll find a option you can activate : "hide pre-installed games". Otherwise, you can hide roms as you always did it before.
        Have fun.
        borg357 1 Reply Last reply Reply Quote 0
        • borg357
          borg357 @Scavy last edited by
          @scavy WTF? Seriously? You can't delete Roms?? Which person decided that was a good idea?
          Scavy Zing 2 Replies Last reply Reply Quote 0
            @borg357 where's the problem as far as you can hide them and put only yours !
            It's a staff's choice, these roms are not set in the share. But, as i told you, you can hide them via the menu.
              Zing Global moderator Translator @borg357 last edited by
              @borg357
              Recalbox only has some pre-installed ROMS that are freeware or that the author has authorized the distribution.
              These ROMS are not in the same folder that the user accesses, and an option was added to hide them easily because many users complained that they already had the ROMS they wanted and didn't want to have to delete the pre-installed ROMS with each update.
              If you connect your SD card to a PC with the help of a USB adapter, you can access the folder with ROMS and add and/or delete your own ROMS.
              It is also possible to connect your Rpi to the network via cable or via wifi, and access the folder with the ROMS via SSH (I recommend using WinSCP).
              The option to delete ROMS directly from the Recalbox menu has been removed to avoid some critical Emulationstation failures, we still don't know if this will be definitive or not, there are several factors that influence this decision.
              • borg357
                borg357 @Zing last edited by
                @zing Thank you everyone.
                Was FTP removed?
                Thanks
                -Richard
                  @borg357 Sorry, I've never used FTP on Recalbox, I use WinSCP or I transfer over the network via file explorer.
                  The documentation specifies that you can use Cyberduck for SFTP connections:
                  • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acces-sftp-ssh-via-cyberduck-macos-win
                  See if these threads help you, they mention the use of FTP (if you use the forum search system, you will find even more mentions of FTP that can help you):
                  • https://forum.recalbox.com/topic/24266/jeux-ports-avec-la-7-2-1/15
                  • https://forum.recalbox.com/topic/23811/xbox-series-s-x-controller-not-pairing-with-recalbox-7-1/3
