    Raspberry pi zero 2 w freezing on menus
    zero freezing
    3195
    • daz
      daz last edited by
      Mine boots up fine ran quite a few things really well but it randomly pauses for a long time & then freezes only seems to do it in the menus not when the game is loaded then I have to reboot to use it hope this bug can be ironed out but impressed so far pi zero 2 w
      Zing Stani420 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @daz last edited by
        @daz https://forum.recalbox.com/topic/25279/gpi-case-pi-zero-2-w-probleme-d-install/7
        daz 2 Replies Last reply Reply Quote 0
        • daz
          daz @Zing last edited by
          @zing thanks i will download & try again
          daz 1 Reply Last reply Reply Quote 0
          • daz
            daz @daz last edited by
            @daz ive just flashed that image but just hangs on the recalbox loading screen i am not using it in a gpi game boy case just plugged into a tv with xbox controller like i say it works fine but will freeze /hang on the menus of systems its like too many presses of the controller makes it freeze in the menus
            when a game is loaded its fine until you go back into the main menu
            • daz
              @zing
              just tried the pi3 b+ download & it works a lot better not crashing in the menus anymore just had to copy the bcm2708-rpi-zero-w.dtb file from the zero 2 w image into the pi 3B+ image for it to work into the recalbox partion were the config file is only wifi doesnt work
              Stani420 1 Reply Last reply Reply Quote 1
              • Stani420
                Stani420 @daz last edited by
                @daz i have the same problem. Did you use the 8.0 beta?
                • Stani420
                  @daz is this a good solution? Anyway to get wifi working?
                  • daz
                    daz @Stani420 last edited by
                    @stani420 hi it works better in 8.0 now & setting to 720p & turning rewind & web interface off but still freezes in the menus after quiting a game must be low memory issue
                    • daz
                      @stani420
                      setting the vram in config.txt to 100mb helps alot & not having too many ROMs in each folder plus everything works fine now unless I play Dreamcast as it will crash on loading or exiting game
                      Stani420 1 Reply Last reply Reply Quote 0
                      • Stani420
                        @daz thanks alot, i will give it a try again 🙏
