    DualSense vibration
    GamePad/GPIO/USB encoder
    dualsense vibration
    • Paril
      Paril last edited by Paril
      Hi there.
      I have RecalBox working great, but with my DualSense controller, it's vibrating to the music/sound of the main menu and games, and it's extremely irritating, lol. Is there any way to disable this feature? I looked all around for vibration settings or others with this issue but it seems like I'm the only one.
        Zing Global moderator Translator @Paril last edited by
        @paril Have you tried changing the driver to see if it still happens?
        • recalboxfan1
          recalboxfan1 last edited by
          I’ve seen someone talking about this before on Reddit: https://www.reddit.com/r/emulation/comments/q2hops/give_ps1_games_a_new_feel/
          The general explanation is that the game audio is flowing through the controller. I don’t have a DualSense myself but I’d suggest looking at the RetroArch menu for Sound and see if you can change the output device to explicitly be HDMI (or component if you use that).
          Confusingly Recalbox has wireless Bluetooth controllers connect under the same menu as a remote Bluetooth speaker so I don’t get the feeling that you can fix this from EmulationStation (the Recalbox front end).
