    Can't shutdown.
    cant shutdown
    1699
    • dasritter
      dasritter last edited by
      On 7.2.2, "shutdown system" and confirm "really shutdown" results only in a reboot of Emulation Station. How can I fix this? Thanks.
        Zing Global moderator Translator @dasritter last edited by Zing
        @dasritter
        • On a computer or smartphone, open a browser (can be Chrome or Firefox, etc.)
        • in your browser's address bar, type:
          http://recalbox/help
        • This will open the Recalbox manager, try shutting down the system from this screen.
        • dasritter
          Thanks but that doesn't work for me either.
          Is there any file I could edit to fix this problem?
            @dasritter
            Did not work? What happens when you try to shut down the system through Web Manager?
            Not without knowing what is causing the problem, I recommend that you do a reset to factory parameters, this option is available through the advanced settings menu, you will not lose any personal files, but you will lose all custom settings.
            dasritter 1 Reply Last reply Reply Quote 0
            • dasritter
              dasritter @Zing last edited by dasritter
              @zing I could not access Web Manager as the wifi connection is flaky.
              I did a full factory reset and the problem persisted.
              I'm running off a 512GB usb stick in a RP400.
              I can sometimes shut down, it works about 20% of the time, seemingly at random. The rest of the time it just restarts EmulationStation.
              If I attempt to restart rather than shutdown, it actually shuts down occasionally - again about 20% of the time.
                @dasritter said in Can't shutdown.:
                a 512GB usb stick
                it looks like your problem is with the storage device, have you tested it with another one to see if that happens?
                • dasritter
                  @zing It could be the storage device, I didn't have this problem running from the SD card. That sucks though, I bought the expensive 512GB flash drive just for recalbox...
                    @dasritter
                    Before you're sure the problem is with the hardware, make sure the problem isn't just a corrupt file.
                    Watch this video (enable subtitles):
                    https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=26&ab_channel=Recalbox
                    Backup the folders mentioned in the video, format your storage device in exfat, and try again.
