    How to copy from MAME to Recalbox and Hardware Compatibility
    Your recalbox
    copy mame recalbox hardware
    • Chakaman69
      Chakaman69 last edited by
      I was curious as to what I need to copy over to the ROMS folder, BIOS, etc. I am trying to migrate away from MAMEUI on my cabinet. Also, I have an X-Arcade Tankstick with a Turbo Twist 2 Spinner. I am going to use a Raspberry Pi 4B and I saw that I only have 4 ports. Am I able to use a powered USB hub with that unit?
      ![0_1629909232111_IMG_0074.jpg](Uploading 8%)
      • Chakaman69
        This is what I meant to say:
        I was curious as to what I need to copy over to the ROMS folder, BIOS, etc. I am trying to migrate away from MAMEUI on my cabinet. Also, I have an X-Arcade Tankstick with a Turbo Twist 2 Spinner. Are these game controllers compatible with Recalbox? I am going to use a Raspberry Pi 4B and I saw that I only have 4 ports. Am I able to use a powered USB hub with that unit?
        Zing recalboxfan1 2 Replies Last reply Reply Quote 0
          Zing Global moderator Translator @Chakaman69 last edited by
          @chakaman69 I don't know MAMEUI, but in Recalbox, inside the ROMS folder, there is a folder for each supported console and inside that folder there is a readme.txt saying which roms are compatible and which BIOS are needed, just follow the instructions.
          For BIOS, it is necessary to have files with exact names + extensions (case sensitive) and MD5, but you can check this in the RECALBOX internal BIOS checker accessible through the Emulationstation menu.
          Here is our compatibility list:
          https://recalbox.gitbook.io/documentation/hardware-compatibility/compatible-devices/controller
          Unfortunately we have a small team and we don't have all possible hardware to test, so we depend on user feedback to confirm which hardware is compatible or not.
          • recalboxfan1
            recalboxfan1 @Chakaman69 last edited by recalboxfan1
            @chakaman69 said in How to copy from MAME to Recalbox and Hardware Compatibility:
            You’ll basically put all MAME roms and BIOS (e.g. neogeo, pgm, zn1) into the mame “roms” folder on Recalbox. Don’t need to use the Recalbox bios folder - MAME is an exception here. The wiki previously linked should have this on the arcade page but I didn’t check (currently on mobile).
            As far as the Tankstick, it worked great but there’s currently a bug (more or less) in recent Recalbox versions preventing it from working correctly. Search the forum for another thread with Xarcade - it contains a workaround file you can download and copy over to the system. This is expected to be fixed I in a future version and I’ve used the stick myself in the past to great effect.
            (Edit: not sure about the spinner….maybe it can be mapped as an analog stick??)
            Lastly, you can definitely use a USB hub but I’m not sure how well the Pi will do with 5+ USB devices… 😃
