    Display color is yellowish.
    Emulator Arcade/PC/Console
    display color yellowish
    • lxknvlk
      lxknvlk last edited by lxknvlk
      Comparison to my retroid pocket 2 - the colors are normal.
      PSX:
      alt text
      alt text
      GBA:
      alt text
      Is it possible to fix it?
        Zing Global moderator Translator @lxknvlk last edited by
        @lxknvlk Sorry, but you are configuring 2 different devices with different screen qualities.
        Honestly, looking at your photos, the impression I get is that your retroid pocket 2 is distorting the original colors... Not the opposite.
        You can test by changing shaders for example, but if I were you I would try to change retroid pocket 2, not odroid go super (and in this case, because it's not Recalbox, I don't know if it's possible, and we don't support ).
