    BlueLake PS3 Controler not pairing
    GamePad/GPIO/USB encoder
    bluelake ps3 controler pairing
    • vwasteels
      vwasteels last edited by
      Hello,
      I bought 2 of these PS3 BlueLake Controlers :
      https://www.amazon.fr/gp/product/B07FVVWJ8Z/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
      They work great with cable, but I cant make it work without.
      I followed the instruction for pairing : plug , wait for it to stop blinking , unplug and pair , but no success
      I tried also to pair manually through SSH
      https://recalbox.gitbook.io/documentation/tutorials/controllers/configuration-test/manually-connect-a-bluetooth-control
      but no luck still, I get :
      Exception: Bluetooth adapter not found
      My Bluetooth Dongle is :
      https://www.amazon.fr/Yizhet-Bluetooth-adaptateur-consommation-dénergie/dp/B01LR8CNXU
      Recalbox is running on a HP Elite Desk at its latest version : 7.2.2
      Also I tried every Driver (officiel, shanwan, bluez) , how can i know which one is the right anyway ?
      Any though on this ?
      Thanks a ot for your support!
      Long Live Recalbox 🙂
        Zing Global moderator Translator @vwasteels last edited by
        @vwasteels Have you already tested without the dongle?
        Unfortunately, there is a plethora of possible hardware and the team can't have them all or even test them all, so while Recalbox has MANY compatible joysticks, not all of them work.
        Probably your problem is a driver incompatibility that only a developer could solve, but for that it is necessary that a developer has a joystick like this and compatible hardware, which unfortunately I think is unlikely.
        We depend on user feedback to ensure compatibility, but your joystick is not listed as compatible:
        https://recalbox.gitbook.io/documentation/hardware-compatibility/compatible-devices/controller
        And your dongle doesn't either:
        https://recalbox.gitbook.io/documentation/hardware-compatibility/compatible-devices/dongle
        Unfortunately, I don't think there is a solution in this case.
        You can try resetting to factory defaults, option available through the advanced settings menu, you will not lose any personal files, but you will lose all custom settings. But it's just a possibility to be tested, I can't guarantee it will solve it.
        Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
