    Is there a way to disable controllers?
    3749
    • mastertank56
      mastertank56 last edited by
      Some games I've noticed seem to believe that there is a multiplayer adapter attached.  This prevents the games from being played.  I would like to disable every controller but 2.  I'm not sure if this would allow the games to work but it potentially could.
      Dinierto 1 Reply Last reply Reply Quote 0
        Humm with which systems?
        • mastertank56
          Seems to be limited to the SNES.  Games like Super Mario RPG and another that was a Tetris/Dr Mario combo both say to detach the multiplayer adapter.  I'm only using a single usb SNES controller.  RP2 with 4.0.0 Beta 2.
          gmkyros 1 Reply Last reply Reply Quote 0
          • gmkyros
            gmkyros last edited by
            Hate to necro, but I didn't see an answer to this or another similar question with an answer (though I am admittedly new and have not had much time to dig).
            Setting players 3-5 to none in the actual emulator menu seems to have worked just fine for me.
            There are big lines between those who play video games and those who do not. For those who don't, video games are irrelevant. They think all video games must be too difficult.
            --Shigeru Miyamoto
            • Dinierto
              Dinierto Banned @mastertank56 last edited by
              @mastertank56 go into the emulator/retroarch menu, go to Quick Menu, then controls.
              • gmkyros
                gmkyros @mastertank56 last edited by
                @mastertank56
                Found that going into the system menu, pressing the select button on the individual game and designating a specific emulator and core resolves the problem. Specifically, I chose pocketsnes I believe and this resolved the issue. Been playing several games that originally gave this error by doing this.
                --Shigeru Miyamoto
