    SMB Share With OPL/PS2
    smb share oplps2
    • xablau
      xablau last edited by
      Hey everyone.
      Since I've update to 7.2.2 my PS2 can't connect to the SMB Server (I use my share folder to play PS2 Games over an ethernet cable).
      No changes have been made. With 6.1.1 works just fine and now with version 7.2.2 it stopped.
      Can anyone help me?
      Zing 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @xablau last edited by
        @xablau
        So you are not using Recalbox, there is no PS2 in the emulator list:
        https://recalbox.gitbook.io/documentation/hardware-compatibility/emulators-compatibility
        xablau 1 Reply Last reply Reply Quote 1
        • xablau
          xablau @Zing last edited by
          @zing I have a PS2 with an etherneth cable plugued in my Raspbery Pi 3b+. On my PS2, I have OPL to load games via network. My USB Drive is pluged in the Raspbery and have the isos are served via network so I play my PS2 (NOT THE RECALBOX). It works on 6.1.1 but not on > 7.
          It appears to be a SMB issue on this new version. Can you help me?
            @xablau
            There is a possibility that you are taking advantage of configuration files from the old version, and this is conflicting with something, I recommend that you try the factory reset, available through the advanced settings menu. This will not affect your personal files, but it will erase all custom settings.
            I have OPL
            Since the OPL is not officially supported by Recalbox, there is a possibility that it will no longer work, but that doesn't mean it's a Recalbox bug: the system wasn't made for it.
